Some thing on my burner
IMPI
What model do you have?: sp2
Been thanked: 78 times
Post by IMPI »
I am thinking of using such a fan in future impi fanshrouds
Re: Some thing on my burner
He he he - I like where this is going...
I see dead Marine :twisted:
Has thanked: 45 times
Been thanked: 208 times
Thats interesting! Looks like you are making an adapter to mount the fan from its 4 posts to the alternator shaft. Then you cut a hole where it used to mount on the crankshaft.
This means air now enters from the back. Direction of rotation is therefore still the same.
Nice idea!
AirPower
Been thanked: 4 times
Post by AirPower »
That looks very good, but I think it's a lot of work :shock: .
You reversed the blades? Never thought that was possible - good one IMPI :D
Mario
Fan is from a Type 4 engine
vader
Post by vader »
'n Boer maak 'n plan!!!!
IMPI
Post by IMPI »
There are a few reasons for doing a fan for a type four conversion this way.
Using the type four fan means you match vws design more closely.
fans with narrow blades like the type four seems to be more efficient.
I can now run the fan at crank speed.
the fan doesnt have to accelerate faster than the engine like a type one.
the fan being a casting does not need to be welded
it is lighter than a beetle fan.
There is some disadvantages though
it is unproven!
it takes some work to build
it will need a completely new fan housing
I am currently designing a completely new type of conversion.
Why would you ask since the original IMPI conversion works extremely well.....
It is simple
I can.
The original Impi is a bit bulky and with the current trends towards throttle bodies and injectors there is less space in engine compartments.
My vision is to make this conversion as simple and easy to fit that a 6 year old can do it.
Good stuff Armand. Keep us curious buggers posted :D
AirPower
Post by AirPower »
I think this is the future! In 2 years time if you haven't got an IMPI hurricane cooler, your ride is SO LAST YEAR :D Porsche - gah bleh - no more.
:hanged:
If the IMPI can keep it cool in the KALAHARI, it will keep it cool ANYWHERE.
:party: :party: :party: :party: :party:
Anothe plus, a slower turning fan will be worth a few extra ponies under foot :D
There is just so little dudes like you left. :? keep up the interest.
Sorry I have never worked on a Type 1:
Will your setup mean that the alternator will turn slower than it normally does?
It's so good to see SA guys making waves with innovations like these :D
vader
Post by vader »
Lets see Jake the snake try to keep up with his DTM.... So yesterdays technology...
Class 11 streeter
What model do you have?: 8.5 Beetles!
Post by Class 11 streeter »
Geez..........you guys...........such venom. :shock:
Armand, what can be done about the reported cavatation the type 4 fan experiences around 4500 RPM?
For a street engine that sees brief full throttle blasts it might not be an issue, but if you can do any high RPM crusing (or racing) it might be worth noting:
http://www.shoptalkforums.com/viewtopic.php?t=68276
I don't know it all, just enough to be dangerous!
Class 11 streeter wrote:Geez..........you guys...........such venom. :shock:
Very interesting :D
