36 DRLA rebuild
echo echo echo
I was referring to a post Beetlepower made, I know you have seen the bigger carbs
I think I got the same filters as you do.. the 100mm K&Ns. Brilliant filters, and the sound...growl
- Has thanked: 36 times
- Been thanked: 50 times
Looks nice, I take it that you're not running velocity stacks inside the airfilters, man they look flat. That's what's nice about the type II engine bay, my K&N filters are pretty high, just have to find someone someday who can get me a decent set of stacks made up.
Gawd, I hope I don't run into problems when doing my drla's over.....
- eben
- Site Admin
- Been thanked: 54 times
R350 for a set. You can get them made by the exhaust boys... A few of them have a decent flaring machine that can flare the pipe to form a small trumpet.
sometimes its who you know, not what you know... noiseboys, yes, but dont try to get a custom exhaust made... they cringe at that idea.
- Has thanked: 4 times
- Been thanked: 98 times
There are dudes in Judith's Paal in JHB that make them will post the No. as soon as I find their card. I have made a couple of sets before using the chrome tips the exhaust dudes use to fit onto the ends of exhaust, only trick is finding the dia. close to what you need and then braze them onto the air cleaner base, have done this for Weber 36 DCD & 36 IDF's, I was looking at some the other day at Midas and the tips were like R65 each so you probably would be better off just getting the real thing.
dont forget about the Terminator carbs... 62mm
