Page 1 of 2
My beach buggy Build
Posted: Fri Oct 03, 2008 9:15 am
by renierdev
So I have been wanting to put up my progress of my beach buggy for a long time, but here goes
Bought it complete, excluding the motor in Feb 2008 for R1000, but the pan was vrot
So I got a new pan, shortened it, coted the bottom with ABE autocot and the top with polyurethane.
Then went on with the body, it had a few cracks which, with the help of my uncle we fixed, body filled and put some spray filler on and I sanded it down, it is now ready for primer, going on today
Before
Re: My beach buggy Build
Posted: Fri Oct 03, 2008 1:37 pm
by Bugger
Bak gat man
Iesh that elbo ghries is a shit part of the whole prosess
Posted: Mon Oct 13, 2008 10:49 am
by renierdev
The body is sprayed and fitted toe the chassis
Wiring is done, lights and indicators are working. It also started with the key for the first time
Fitted one seat and sat in it for a while, felt good.
One thing that is a bit of a worry, I am over 6ft and it feels as if the sides of the body is to low - i.e. it does not cover much of my hip, maybe some of the other buggy owners can give me a indication of how there buggy sits?
Posted: Mon Oct 13, 2008 8:14 pm
by hitlers revenge
Hi Renierdev, That sounds pretty high. I am also 6ft and don't sit that high. What seats have yiu got in the buggy? Where are you based? Maybe I can make a turn so you can see mine.
Posted: Mon Oct 13, 2008 11:06 pm
by AirPower
Hi Renierdev
I'm also busy building a buggy - what kind of seats are you using?
I had some problems getting enough clearance between the steering wheel and seat on the driver side, at the moment it's a still a tight squeeze (and I'm not that tall). Try and mount the seats as low as possible. I used a pair of after market seats and bolted them onto the floorpan using only 25mm square tubing for a spacer.
Mario
Posted: Mon Oct 13, 2008 11:15 pm
by Pine
If you use the bottom part of a standard Beetle seat railings, and bolt a bucket to it, it sits just right. Standard Beetle seats on their own are too high.
Posted: Tue Oct 14, 2008 7:32 am
by renierdev
I took the beetle seat rails and modified them so they are as low as possible, and fitted some buckets to them, maybe it is right but does not look and feel right to me.
There is enough space between the steering wheel and my legs, more than I thought.
I'll post a pic, and maybe HR you can see how the seats look in comparison with yours(jislaaik my engels is skoon aaptwak - maar ek dink dis ongeskik om in afrikaans te "post" as daar so baie engelse mense ook hier deur die "site" gan)
Posted: Tue Oct 14, 2008 9:52 am
by Blitzkrieg
Ons kan Afrikaans ook verstaan
Posted: Tue Oct 14, 2008 9:40 pm
by lowlight
Posted: Tue Mar 24, 2009 9:09 pm
by renierdev
this is a picture taken in December over the holidays
buggy know only needs registration and roadworthy, still finishing up a few small minor stuff
Nice view of Meeurots in Yzerfontein in the back round, I bet Eben is missing home know...
Posted: Tue Mar 24, 2009 9:21 pm
by Chris
You did a fantastic job.Well done.
Posted: Tue Mar 24, 2009 9:23 pm
by buggyfan
hi renier ,the buggys looking good!!!!
when you replaced the windshield ,was it only the glass or the frame aswell that you replaced ??
Posted: Tue Mar 24, 2009 9:25 pm
by renierdev
i only replaced the glass, cost me R400 for the glass at national auto glass
Posted: Tue Mar 24, 2009 9:32 pm
by buggyfan
renierdev wrote:i only replaced the glass, cost me R400 for the glass at national auto glass
yeah ,i still have to get mine cut aswell
Posted: Wed Mar 25, 2009 2:29 am
by beetlefanatic
I like the red. Good job!
