Lost in VW heaven
Posted: Fri Apr 18, 2008 5:39 am
by Tjaart
O.K.now with the Beetle engine trashed(look at what kind of engine) the options are as wild and wonderful as there are exotic places in this world. To get a type 4 engine in the bug , sound nice,but that bleddie oil cooler is in the wrong place.Any suggestions there.I would like the thing to look like a Beetle afterwards. How the hell the guys get 94mm sleeves and pistons in a bug block is another mystery. Somebody give light please.
Re: Lost in VW heaven
Posted: Fri Apr 18, 2008 6:33 am
you can buy kits with 94mm pistons and sleeves designed for the T1 engine....
look for my suicyde engine in projects section and read some of the tech pages
Posted: Fri Apr 18, 2008 9:07 am
by Blitzkrieg
Tjaart wrote:O.K.now with the Beetle engine trashed(look at what kind of engine) the options are as wild and wonderful as there are exotic places in this world. To get a type 4 engine in the bug , sound nice,but that bleddie oil cooler is in the wrong place.Any suggestions there.I would like the thing to look like a Beetle afterwards. How the hell the guys get 94mm sleeves and pistons in a bug block is another mystery. Somebody give light please.
The oil cooler stays in that place if you use IMPI's fan housing shroud kit to convert the Type 4 into upright
Posted: Sun Apr 20, 2008 12:21 am
by Bugger
Take a look at the engin bay this was a 2.1L Type 4 in my one Oval bug and I built a all steel fan housing with the twinport fan in the housing and sealed the engin compartment from hot exhaust air comming in and had a long 4th gear in there for highway croozing with out any cooling problems
And this is my Other Type 4 2.3L turbo motor with 2x BMW 50mm throttles on and a modyfied glass fibre and steel fan housing and all the bottom tin ware still bolts to the top housing for propper cooling
And this was one tank of fuel and 3 clutches with 200mm flywheel set up before I used 228mm clutches from the 2.1 and Type 4 and can handle much more power than a beetle one
