Beetle tires - where to buy in Cape Town
Posted: Tue Jan 07, 2025 1:19 pm
by No More Landy
Hi all.
Where can I buy original size tires.
I bought a set of original rims.
My only spare is marked 5.60-15
Re: Beetle tires - where to buy in Cape Town
Posted: Wed Jan 08, 2025 12:44 pm
by No More Landy
I spoke to Dunlop directly and they say there is possibly a factory in Zim that still produces old model vehicle tires but no details of this
Sent from my SM-A546E using Tapatalk
Posted: Wed Jan 08, 2025 5:06 pm
by 73type2
I see Autostyle has a 165R15 for R1395 each. Brand is Vitour. That’s the only one I could find in South Africa. If you google Vitour it shows they’re a tyre manufacturer in Athlone, Cape Town.
Posted: Wed Jan 08, 2025 6:17 pm
by No More Landy
73type2 wrote:I see Autostyle has a 165R15 for R1395 each. Brand is Vitour. That’s the only one I could find in South Africa. If you google Vitour it shows they’re a tyre manufacturer in Athlone, Cape Town.
Hi 73
Will that be the closest to the original?
Posted: Wed Jan 08, 2025 7:08 pm
by 73type2
Yes. I’m also in need of a set for my ‘71 1300DP. I’m going to look around soon.
Posted: Wed Jan 29, 2025 9:13 pm
by No More Landy
Found a set of 15 inch tires with a go faster white stripe on the sides.
Does anyone know what the length of threads should be as I had to change wheel bolts due to the different seating on the chamfer.
The new bolts I got at flat four are way long so I need to machine them off at work.
Posted: Fri Jan 31, 2025 8:45 am
by 73type2
The thread length is 19mm. I’d suggest that you return those bolts and buy the right ones at Goldwagen, code A657. Check their online partsfinder website.
Posted: Wed Mar 19, 2025 4:05 pm
by No More Landy
Anyone that can recommend an alignment place that can still accommodate the old beetle and adjust kingpin shims according to camber ?
I also need to replace the rear suspension bushing which is squeaking like hell and try reset the rear torque arm timing as last time I messed it up and it's not sitting right between left and right rear.
Posted: Fri Mar 21, 2025 2:55 am
you are not going to find anyone who does that anymore. You'll have to do it yourself.
