Beetle Spark Plug Life
No More Landy
What model do you have?: Beetle 1971
Has thanked: 23 times
Been thanked: 6 times
Germany
Post by No More Landy »
My Beetle has been running quite well for some time, but all of a Sardine, from one day to the next run's like a pig.
Thought it was a blockage in the carb so I stripped and fully cleaned but found no smoking gun.
She shakes quite badly, so it sounds like not firing on all cylinders.
Have all new plug leads, new coil, condenser and points and plugs not that much mileage but at least 1 year old.
Took out two plugs and measured the resistance with a multimeter between the end and the body and found one att 8 Mega Ohm and the other at 0,379 Mega Ohm. The one with high resistance seemed to have soot on the end showing it was firing but the other was clean as if not.
This is the second time that I have a dead plug after relatively low mileage, that is why I changed all the above bits.
Any ideas from the experts.
Thanks guys
1971 Beetle
2021 Polo tsi
2006 Defender Kalahari
Camshaft
Been thanked: 107 times
Re: Beetle Spark Plug Life
Post by Haans »
Mornin t'you kind Sire,. It seems that all the engine "ghurus" have gone into hibernation already !!!
but,... we've had a similar issue on a bay mostly no 3 cylinder,... now I'm no expert but ,...
is it a specific cylinder,. or random ?
check compression ? if not random
swop plug leads around and see if the "dead" plug follows a lead ??
valve adjustment settings etc ??
this is just to get your mind in gear to start eliminating some issues to get to the bottom.
with the bay we went with a plug hotter in the range,...purely because the distances we travel was mostly less than 8 km per trip,.... yes it did help in our situation.
and yes the motor was fairly tired as well !
hope this trigger some brain waves !! good luck
regards Haans
No More Landy
Germany
Changed all 4 plugs yesterday for new and she runs so sweet again.
Tested all old plugs on my multimeter and there was only 1 that was good. Remaining 3 had resistance which is no good.
Sent from my SM-A546E using Tapatalk
1971 Beetle
2021 Polo tsi
AlanH
Has thanked: 118 times
Been thanked: 86 times
Germany
Post by AlanH »
What make were the old plugs and new?
I have heard to stay away from a certain brand but cannot remember which. I was also recommended a brand and would need to check as I bought a set to keep in the bus for spare.
Wanted parts:
Left sunvisor
Sink faucet
Been thanked: 487 times
the fault could lie in anything from the condensor being wrong to leaking rings
I've only had one plug die on me in the last 10 years and I am using my vehicles fairly often.
I did however kill 4 when I decided to open my plug gap from 0.6mm to 1mm to test my fancy MSD 5220 ignition system. The spark wasnt big enough to handle those gaps and I killed the plugs in under 100km.
I've also had someone come to me with issues of fowling plugs regularly and if he puts in new plugs, the car runs well for 20 min then doesnt hardly runs anymore - that turned out to be leaking needle valves in the carbs.
If you dont have any obvious faults in your system and EVERYTHING is working as it should, then I'd reset the plug gaps to 0.5mm (make it 0.1mm smaller than its supposed to be).
Also ensure that your point gap it correct and your timing is right.
No More Landy
Germany
AlanH wrote:What make were the old plugs and new?
NGK
Sent from my SM-A326B using Tapatalk
1971 Beetle
2021 Polo tsi
I've had the best success with Champion N7YC plugs
No More Landy
Germany
Drove her today for 30km and at one point had a miss fire again for a short time but it went away.
Let's see how long they last
1971 Beetle
2021 Polo tsi
