Aircooled VW South Africa • Engine Tin - coating advice
Posted: Wed Sep 20, 2023 12:32 pm
by No More Landy
Hi Guys
Anyone that can recommend a process to coat engine air cooling ducts/bits and pieces including fan housing ?
I did mine about 6 years ago but all that coating is gone. (Mostly)
At the time I had them sandblasted but can't remember the type of paint coating they put on after.
Thanks in advance.
Re: Engine Tin - coating advice
Posted: Thu Sep 21, 2023 3:21 pm
I've used powder coating quite a few times, always with good results
Other than that, just applying Hammerite also works
Posted: Wed Sep 27, 2023 5:52 pm
by Riaan.N
+1 for powder coating.
Rust-Oleum “enamel” spray cans are my go to paint for small parts. Alternatively automotive 2K, but here the primer becomes becomes important.
Surface preparation is also important.
Posted: Sun Oct 01, 2023 9:07 am
by No More Landy
Ended up using Quality Coatings in Paarden Eiland as per the owner of Flat Four's suggestion for powder coating.
Brilliant job and cheap as chips.
Posted: Sun Oct 01, 2023 12:08 pm
by 73type2
Good to know. Thanks for the tip.
