I have two brand new heads (From Tony Z) and new valves I bought at Alert Engine parts.
Does one need to grind in brand new valves and seats or at least do a blue test. ?
Also, should I lap/grind in the existing cylinder barrels into the new heads ? Still need to mic the bores but the ring gap is 0.6mm of the newish rings.
Beetle Head Advice
- No More Landy
- Has thanked: 23 times
- Been thanked: 5 times
- Wentzel
- Has thanked: 6 times
Re: Beetle Head Advice
Hi I always lap different valves since they will be different. The cylinders may or may not need it I would lightly lap check and go from there.
What I would at least.
Oxyboxer Project
- No More Landy
Thanks. Will do
Sent from my SM-A326B using Tapatalk
1971 Beetle
2021 Polo tsi
2006 Defender Kalahari
2021 Polo tsi
