For the life of me I can never figure out how these engine codes work. Google searches etc also just confused me further…..
I have an engine with number: SFFR 166445
As far as I could figure out its a SF (South African factory) Remanufactured (R) 1300 single port (3rd letter- F)
Is this correct?
Another Engine number deciphering please
- white_356
- What model do you have?: Splitty,356,Westy,KG
- Has thanked: 23 times
1960 Karmann Ghia
1960 Split Window Kombi
1969 Beetle 1500 LHD (Project)
356 Speedster Replica
1970 Lowlight Single Cab Bay
1972 Westfalia
1989 Syncro (2.5 Suby)
2017 VW T6 Transporter 4motion
1972 Westfalia
- Has thanked: 42 times
- Been thanked: 207 times
Re: Another Engine number deciphering please
Engine prefix letter "F" or SFF was indeed a single port 1300 from around 1966-1967.
Code "AR" or "SFAR" was the late 70's dual port 1300. Engine casing would be marked "AS21", which refers to the alloy used.
As you mention, the factory sometimes added "R" to mean reconditioned. Until local law was passed which made it illegal to tamper with engine numbers. Think that law happened somewhere around the late 80's. Or early 90's. Because of increasing crime at the time.
(There was a time, so crime free, that some local manufacturers like VW even stopped stamping chassis numbers on their cars. Only the riveted on info plate had the chassis number. That was early 70's.
sounds like a utopia
