Type 2 combi and type 412 gearbox the same?
mhsmuts
Been thanked: 4 times
Post by mhsmuts »
Hi all
Does anyone know if the Variant 412 and the type 2 kombi has the same gearbox?
Thanks!
Sent from my SM-G996B using Tapatalk
sean
Has thanked: 63 times
Been thanked: 227 times
Re: Type 2 combi and type 412 gearbox the same?
Post by sean »
mhsmuts wrote: Mon Aug 22, 2022 6:54 pm Hi all
Thanks!
Hi
Not the same at all.
Regards
Sean
mhsmuts
Post by mhsmuts »
Hi Sean
Do you mean ratios or physical size and geometry?
I have a 4y in my 412 (with adaptor) and want to transplant it into a type 2 bus
sean
Post by sean »
mhsmuts wrote: Mon Aug 22, 2022 8:47 pm Hi Sean
The ratios wont be the same, but I was referring to it externally. Its completely different in size and mounting points.
Has thanked: 45 times
Been thanked: 208 times
Nothing is the same. Type 4 transmission and its parts are different from al other transmissions. Closest family is the Porsche 911 transmission which has been transplanted into type 4 cars before. Although none of the internal parts are the same. On a 911 the shift shaft exits at the bottom below the Porsche's torsion tube. Type 4 transmission's shift shaft is in the same low position. Kombi/ beetle's shift shaft goes above torsion tube.
Type 4 transmission should be mounted as to have no weight on the front nosecone. After problems with the first few cars, vw changed the mounting system which solved an issue. Since then vw only used bump stops in that position on the 411/412. Otherwise the light casing distorts causing damage inside. (Gear design clearances can often be critical, if its out by a few microns or running skew, high rate of wear can result).
Diff is also weaker than kombi box. Especially 1st gear ratio will be too tall for heavy kombi use..
Best would be to keep the Kombi box and get a new adapter plate for the motor to mount on the kombi box,
There are a few adapter plate around, you may even be able to get one from guys on this forum.
Good luck with the conversion.
AlanH
Has thanked: 125 times
Been thanked: 86 times
Germany
Post by AlanH »
If the 4Y and 3Y engines are the same I have an adapter plate available.
Wanted parts:
Left sunvisor
Sink faucet
mhsmuts
Post by mhsmuts »
Dawie wrote:Nothing is the same. Type 4 transmission and its parts are different from al other transmissions. Closest family is the Porsche 911 transmission which has been transplanted into type 4 cars before. Although none of the internal parts are the same. On a 911 the shift shaft exits at the bottom below the Porsche's torsion tube. Type 4 transmission's shift shaft is in the same low position. Kombi/ beetle's shift shaft goes above torsion tube.
Thanks Dawie
mhsmuts
Post by mhsmuts »
retrovan wrote:Best would be to keep the Kombi box and get a new adapter plate for the motor to mount on the kombi box,
Thanks Herman
https://www.giloeng.com/adapterparts.htm
All the info you need
Enjoy
sean
Post by sean »
How on earth did you fit a 4Y motor into a variant? Where did you put the radiator?
Think at the time there was a photo from bull run showing a large hole in the front...
I was thinking if the gearbox oil seal leak previously mentioned was related to the conversion. If an adaptor plate is a bit skew/off centre, or too thick, this has been known to cause damage/oil leaks to transmission. Sometimes the input shaft is not well supported causing damage. Then replacing the seal might solve issue for a short while.
mhsmuts
Post by mhsmuts »
As Dawie says below we fitted it in the nose, cooling worked perfect. Fan hardly had to come on. I think the length of piping to back and return helped with the cooling.
mhsmuts
Post by mhsmuts »
Bull run Image
Are you scraping the 412 or changing engines
