Golf4 gti misfires
Posted: Wed Jun 08, 2022 7:57 pm
by lotteringjoshua3
Hi I own a golf4 gti bought the car recently by a guy but I did not drive the car away from there coz of a missing key I towed it away after laser cutting new key I heard the car had a misfire checked camshaft sensor checked air flow spark plugs module ignition coil everything is 100% spark plugs burning white but still have a misfire when I pull in a second gear dies out under my foot what could be the problem really need the help
Sent from my SM-J400F using Tapatalk
Re: Golf4 gti misfires
Posted: Fri Jun 10, 2022 2:48 pm
by V6 Capri
Posted: Fri Jun 10, 2022 2:54 pm
by V6 Capri
Sounds like it happens when under load?
Plugs burning white is either it running lean, or too hot.
Check the injectors and fuel pressure maybe?
Could be timing is out and the injectors or spark plugs fire at the incorrect time too?
Posted: Fri Jun 10, 2022 10:44 pm
by lotteringjoshua3
V6 Capri wrote:Sounds like it happens when under load?
Thanks will check that out it does have a small back fire could be timing
