VW Baja Bug Conversion - Need roof cover ideas
Pricilla
What model do you have?: 1974
Post by Pricilla »
Good day,
My son has a VW Baja Bug that was converted to look like what you would see in the picture [this is his vehicle].
Can anyone give us some kind of idea on how to put on a cover on the roof for rainy/cold days?
We want it in such a way that when there should be back passengers [which would not always be the case] that they are also covered.
But mostly the back cover would we up permanently - and only the driver passenger roof section would be removable
Any ideas would be much appreciated. We need ideas for a kind of frame structure for the back so that it can be covered.
Been thanked: 539 times
Re: VW Baja Bug Conversion - Need roof cover ideas
The best is to take it to a canvas shop and let them cut and stitch something for you
You may have to make 2 or 3 goal post frames for the back end that will fold down on the back edge.
Then have two door flaps made that will fix onto the body with turn clips & eye holes.
