Lets talk about lightly modded 1600 TP engines
- What model do you have?: Not yet
- Been thanked: 2 times
Hi guys
With my bug currently in progress ,id like to talk about my motor.
Ill be pulling the motor to replace all seals and gaskets soon .
Its a stock 1600 TP and will be adding the following
Dellorto 36DRLA Twins
Compufire electronic ignition
38mm Empi merged header with PhatBoy silencer (this will be made by local silencer shop)
Stinger will be fitted to annoy the neighbours occasionally
I dont want the car super fast as it will be handed down to my son in the next year or so. I just want to have abit of cruising fun with my wife for now .
Share your thoughts
Share your thoughts
Re: Lets talk about lightly modded 1600 TP engines
light mods are a very personal thing, different things for different guys.
My engine renewal for the Hahn is hoping to include the following.;-
MP9 ECU from a Golf/Jetta mapped for the beetle engine
Fuel injectors from the Golf range
Golf spark bank
Ported heads
Mild 4 into 1 exhaust.
Counterweight crank.
1776 barrels and pistons.
But thats just me,
Your set up will be exciting as well.
Thanks for sharing.
Golf spark bank
Ported heads
But thats just me,
Thanks for sharing.
- Has thanked: 191 times
that compufire setup will leave you stranded at some point. I've had 4 and they all failed in under 1000km.
I now have one paired up with a Gtech unit and it works well, going on roughly 3000km now.
With your carbs and exhaust, to add fun, ported and modified heads and slight lightening of the flywheel will make the car very enjoyable to drive.
To be perfectly honest, I cannot remember at this point. It isn't difficult, but without referring to my bus, I'm drawing a mind blank right now. I'll only be home in Feb again...
Also, it's not something that we endorse yet.
I've said for years that it isn't the heat that kills the compusfire style units, but rather the load. Pretty much everyone else disagrees with me. But I'm proving it...
- Pushrod
- Has thanked: 141 times
- Been thanked: 100 times
Feb is a bit far off, so I’m anxious to try to figure it out. Maybe you’ll remember something. G-Tech replaces the capacitor, so is wired as per supplied diagram. Accuspark replaces points and will now act as a low current switch.Accuspark Red wire is connected to G-Tech green wire and black goes to ground. Am I on the right track?
thats pretty much it.
I dont have the wiring diagram with me right now, so cannot confirm the colours. As you said, it replaces the points
BTW, we have plenty G-Tech and new bosch coils in stock. My wife has access to them, so you can still get them without needing to wait.
- Pushrod
Thanks, I’m already running G-Tech in my bug and have an Accuspark in a spare distributor. I’m quite happy with the G-Tech in the bug, but I’m contemplating eliminating points all together. I’ll let it marinate in my head for a while, before I take the plunge.
Very interesting, let us know how to wire the combination of the 2
I will be getting the gtech too
- Pushrod
Hi Tony. It’s Feb so I assume you’re back home? Could you please confirm the wiring in your bus? I don’t want to fry anything.Tony Z wrote: ↑Mon Dec 27, 2021 1:17 pmTo be perfectly honest, I cannot remember at this point. It isn't difficult, but without referring to my bus, I'm drawing a mind blank right now. I'll only be home in Feb again...
I sent you a pm yesterday. About the heads.73type2 wrote: ↑Fri Feb 04, 2022 10:45 pmHi Tony. It’s Feb so I assume you’re back home? Could you please confirm the wiring in your bus? I don’t want to fry anything.Tony Z wrote: ↑Mon Dec 27, 2021 1:17 pmTo be perfectly honest, I cannot remember at this point. It isn't difficult, but without referring to my bus, I'm drawing a mind blank right now. I'll only be home in Feb again...
Will check on wiring as soon as I get a chance.
Otherwise, you are welcome to visit me early tomorrow morning and we can check it out together
