Hey everyone
I have a random collection of South African 1971 and German imported 1972 Westfalia Kombi spares for sale as a job lot. I’m leaving town at the end of the month and it all has to go. I’m asking only R4000 for the lot, I need travel money urgently. Buyer to collect, I cannot deliver. I am in Incolae Road in Muldersdrift, just off Beyers Naude drive.
Items as follows
Two 1971 front brake discs and calipers, probably need seals and bearings, 23 wheel-nuts
Roof rack, combination of wood and metal, recently restored and repainted
1972 Westfalia single stool for behind passenger seat, storage beneath, new foam cushions, original blue tartan coverings, cushion coverings for rock and roll bed, poor condition and faded but some parts might be reusable
1972 Westfalia dining table, slightly modified but unrestored
1972 Dormobile stretcher beds, metal frames in excellent condion, stretcher material and vinyl covers will need replacing. Originals kept here to use as templates
Jerry can, no leaks, age unknown
Blaupunkt radio frequency extender from the 1972 Westfalia
Rubber tread for passenger side step
Oil bath air filter from the 1972 Westfalia, good condition, with mounting bracket
Various ventilation tubes from under dash
Two inline fans for under dash, with switch and panels, rare, was fitted to the 1972 Westfalia
Towbar with towball, spare towball, all electrical plugs and sockets, mounting bolts
Steering column with steering wheel and ignition switch, no key
Hooter, ashtray, gearknob
Three 1971 lowlight indicator lenses, condition not great, but will work in a pinch
Handbrake support bracket
Between-seat bracket to support double passenger seat
Original 1972 Hazet 4-way wheel spanner
Size 46 socket for rear wheel nut, with power bar
Various sliding door parts, mostly in good condition, see photos
Three “Eyelids”for headlights
Three VDO gauges, battery voltmeter, oil temperature and oil pressure
Two sunvisors, poor condition and damaged
Driver’s side door panel, damaged below but can be repaired
Windscreen wiper motor, assembly and fittings including 2 wiper arms
Handbrake handle and mounting
Windscreen washer bottle
Two headlights
Two indicator stalks, incomplete for spares
Centre rearview mirror
Three interior lights
Seven hubcaps, varying condition
Two hanging strap handles
Two jacks, one marked “Bilstein”
Four metal airvent trims for front of dashboard
Dashboard insert with speedo and fuel gauge, marker lights etc
Cubby door
Various dashboard switches, light, wiper, hazard, rheostat for varying wiper speed, cigar lighter without socket
Couple of other minor odds and ends but this is the most of it.
071 213 1664
Kombi spares
- Single Port
- Has thanked: 13 times
Re: Kombi spares
Score!
- buggyfan
- Long Block
- Has thanked: 95 times
- Been thanked: 87 times
Re: Kombi spares
@Coop what happend to the Marigold project bus?
- CooP
- Clutch
- buggyfan
- Long Block
Re: Kombi spares
Looking good.
Safe travels and yes please do start the new thread
- CooP
- Clutch
