Sealing nuts???
Been thanked: 100 times
Sealing nuts???
I'm busy putting a Beetle 1200 engine back together and found sealing nuts used on the case. I would like to install new ones, but find that the closest nut in South Africa is nyloc. I read that the sealing nut has a rubber insert. Does anybody know where in South Africa I can get these sealing nuts, or can I just go ahead and use nyloc nuts?
Original nut:
slak
Has thanked: 7 times
Been thanked: 32 times
Re: Sealing nuts???
Post by slak »
Seen them at Volkspares before but the last time i wanted they had no stock
but that was a while ago
U Only Live Once Right !!!
Been thanked: 487 times
Re: Sealing nuts???
you arent going to find them locally.
Use nylocs or standard nuts with copper washers
Re: Sealing nuts???
Use some RTV sealer at the base of the stud threads before bolting on the nut, does the same job.
Edmond
Has thanked: 22 times
Been thanked: 31 times
Re: Sealing nuts???
Post by Edmond »
Flat four racing used to seal these in a pack of 4 for the oil pump cover, they were not cheap something like R50 for 4
Re: Sealing nuts???
I use shellac gasket sealer (that molasses like stuff) at the base of the studs.
Edmond
Re: Sealing nuts???
Post by Edmond »
73type2 wrote: Fri May 28, 2021 1:01 pm I use shellac gasket sealer (that molasses like stuff) at the base of the studs.
Thats my favourite sealant to use on beetle engines as well
