I've done a search on this site for VWSA gearbox identification, but didn't get a definitive answer. I have the following numbers off two gearboxes:
Gearbox 1:
28
113 301 103
J
Gearbox 2:
16
113 301 103
Gearbox 2 comes out of my Beetle 1200 and has the short shafts, so I'm pretty sure it's a 1200 box. I'd like some help identifying gearbox 1.
South African Gearbox Codes
- Donovan D
- Has thanked: 148 times
- Been thanked: 73 times
Re: South African Gearbox Codes
The number you looking for should be a stamped number as far as I know to correctly identify the box
Should start with SF
If my memory serves me right, its above the filler plug,
But not too sure
But not too sure
- Has thanked: 141 times
- Been thanked: 100 times
I crawled under the car and found the following code underneath the numbers previously shown:
AC 4288796 SF
According to online sources this gearbox is for 1500 and some 1300 from 8/70. Is this correct for South African gearboxes? If so, I have a 1600 single port that I want to put in this Beetle. Will it be fine?
AC 4288796 SF
