I drive a 2002 VW Caravelle T3 - only has 90 000kms on the clock - (vehicle still in excellent condition)
My radiator fan switch stopped working - I bridged this fan switch but fan still not coming on - what to look for next??.....
All fuses in the fuse rack is ok - except I discovered a 30A fuse above the fuse rack in between the relays that is blown -
Is this the fuse for the radiator fan switch relay?? -
Please help to identify the relay or relays for the radiator fan switch? -
I believe the main fan has 3 x relays - is this true? if so how do I identify them??
I await your kind responses...
Thank you Tony
