Hi ..all ...
I redone my 1.6 ..vw mk1. 8v and it was running fine ....the next moment oil light comes on and lifters are noisy...so replaced the oil pump again from goldwagen changed the oil filter ....still oil light comes on ....took it out on the road and on rev it up a bit and again oil light and buzzzer ...comes on ....bleed the oil pump and took of the valve cover and there is oil on the cam ....but will have to check the oil pressure with n separate gauge .....what i don't understand is that it sounds like there is only one lifter that goes crazy .....pls any ideas what i can look for
Tx Danie
Sent from my SM-J610F using Tapatalk
