Front axle checks.
Posted: Mon May 25, 2020 7:04 pm
I am about to remove the front axle of my Westy to get better access to the wheel wells.
While it is out I will obviously give it a proper clean, since it has lots of gunk caked onto it.
While I'm doing that and the axle is out are there things that are recommended to do in terms of seals, and checks.
Greasing is the obvious one, but what else is recommended?
I see some rubber boots have seen better days so they will need replacing. Any suggestions of where to get an possibly part numbers? What is good quality and what to stay clear of?
Thanking you in advance and looking forward to positive replies.
