Crank pulley oil seal keeps popping out.
Posted: Tue Mar 03, 2020 7:11 am
by german
This is not air-cooled related don't know where to post it. Hope someone can give me advise please. I bought a Hyundai h100 2.6diesel bakkie and the t/cover oil seal keeps popping out. No sump compression but a little bit of end flow. I don't want to renew thrust washers as it runs perfectly. Is there some kind of loctite or any other suggestions please?
Re: Crank pulley oil seal keeps popping out.
Posted: Thu Mar 05, 2020 4:47 pm
by Terry Phillips
german wrote: Tue Mar 03, 2020 7:11 am
Have you checked the breather is not blocked, I know you say no sump compression but take the breather off and check and clean it.
You can get a Loctite but silicone sealer is as good, I don't know about the end float so much it would have to be bad before it could effect the seal. Take the tappet cover off if the breather comes from there and have a good look at the breather. Make sure you use the right seal get one from the agent it might cost more but at least you know its right .I never use a sealer or Loctite putting seals in but that's just me.
Posted: Thu Mar 05, 2020 7:22 pm
by german
Thanks Terry. Yes I have checked the breather which is ok. I also tried a genuine seal and cannot see endfloat causing it but according to the agents it is a problem. I took a sharp centre punch and punched it like we used to with alternator bearings loose in the casings and will see what happens.
Thanks for your comment
Posted: Fri Mar 06, 2020 1:11 pm
by Terry Phillips
Sell it buy a Toyota.
