Assembly Lube
Harry Jones
Assembly Lube
Post by Harry Jones »
When assembling a new engine what is the best locally available assembly lube ?
Terry Phillips
Has thanked: 193 times
Been thanked: 121 times
Zambia
Re: Assembly Lube
Post by Terry Phillips »
I use EP90 and have done many a engine never had a problem.My 2c worth.
Re: Assembly Lube
my first few stock engines I built with engine oil, no issues there.
I've been using my own special concoction ever since, but that one is a secret
Harry Jones
Re: Assembly Lube
Thanks Terry and Tony !!
Doing some reading and research I see the guys also use
Wynns Advanced engine treatment ... have either of you heard of this ?
https://www.wynns.co.za/product/advance ... treatment/
Terry Phillips
Zambia
Re: Assembly Lube
No no no Wyns has Teflon in it and coats everything with a film and does not help the bedding in progress trust me on this its bad news for new engines. No additives and use a straight SAE 30/40 oil not multi grade to run it in. My opinion and experience.
Assembly use EP90
