BRAZILIA STARTER MOTOR AND FLYWHEEL ISSUES
Posted: Sat Jul 27, 2019 1:42 pm
IS THERE SOMETHING I'M MISSING OR DON'T KNOW ABOUT?
SO IN ANTICIPATION OF GETTING CYNDI'S BRAZILIA WE'VE BEEN USING IT QUITE A BIT LATELY. UNFORTUNATELY WE HAVE HAD A BIT OF A BAD LUCK RUN.
THERE WAS A LOT OF NOISE WHEN TRYING TO START THE BUS AND EVENTUALLY IT WOULDN'T SWING THE ENGINE. IF YOU LEFT IT IN GEAR AND ROCKED IT AND THEN STARTED IT, IT WOULD START ALBEIT WITH A HECK OF A NOISE. EVENTUALLY NO MATTER WHAT WE DID IT WOULDN'T SWING ALTHOUGH YOU COULD HEAR THE STARTER TRYING TO ENGAGE.
AFTER REMOVING THE STARTER MOTOR AND CHECKING THE FLYWHEEL WE SAW THAT ALL THE TEETH HAD BEEN EATEN OFF.
WE DROPPED THE ENGINE AND REPLACED THE FLYWHEEL, BRASS BUSH (WHICH WE PRIMED) AND ANOTHER STARTER MOTOR.
FOR A COUPLE OF DAYS IT STARTED FINE BUT STILL HAD A BIT OF NOISE.
ON FRIDAY IT STARTED PLAYING UP AGAIN AND THEN TWICE I HAD TO PUSH START IT.
I BROUGHT IT HOME AND DROPPED THE ENGINE AGAIN.
THE GEAR HAS BEEN EATEN AGAIN BUT NOT QUITE AS BAD, BUT WHAT WAS MORE ALARMING WAS THAT THE FRONT OF THE BENDIX HAD SNAPPED OFF INSIDE THE BRASS BUSH?????
AM I JUST HAVING A RUN OF BAD LUCK OR DOES THE BRAZILIA USE A DIFFERENT FLYWHEEL OR STARTER MOTOR TO THE BEETLE?
I HAVE OBVIOUSLY REMOVED THE OFFENDING STARTER MOTOR AND REPLACED IT BUT DON'T HAVE ANOTHER FLYWHEEL SO I AM STICKING WITH THE ONE I HAVE IN THERE AT THE MOMENT. I'M HOPING IT DOESN'T CONTINUE TO GET CHEWED UP.
THE NOISE IS STILL THERE WHEN STARTING BUT NOT NEARLY AS BAD.
ANYONE ELSE HAD THIS EXPERIENCE OR KNOW THE CAUSE?
MARK
MARK
