Page 1 of 2
Gasket set
Posted: Fri Mar 01, 2019 10:47 am
by Terry Phillips
Can someone tell me if the gasket sets for a 1600 single port is the same as the Twin Port motor.
Re: Gasket set
Posted: Fri Mar 01, 2019 10:51 am
by JonnoDub
Terry Phillips wrote:Can someone tell me if the gasket sets for a 1600 single port is the same as the Twin Port motor.
When you buy a gasket set it has both the twinport and single port gaskets. AFAIK
Sent from my FIG-LX1 using Tapatalk
Re: Gasket set
Posted: Fri Mar 01, 2019 10:55 am
by Terry Phillips
Thanks Jono is R228 a fair price its a decent brand.
Re: Gasket set
Posted: Fri Mar 01, 2019 10:56 am
by JonnoDub
Terry Phillips wrote:Thanks Jono is R228 a fair price its a decent brand.
Quite fair
Re: Gasket set
Posted: Fri Mar 01, 2019 11:14 am
by Terry Phillips
Power Torque is that brand ok Jono sorry for all the questions.Thanks
Re: Gasket set
Posted: Fri Mar 01, 2019 11:44 am
by 73type2
Are the pushrod tube seals white?
Re: Gasket set
Posted: Fri Mar 01, 2019 1:31 pm
by Terry Phillips
I never asked them,are the white ones not so good.
Re: Gasket set
Posted: Fri Mar 01, 2019 2:18 pm
by 73type2
I saw discussions here that the white ones are recommended.
Re: Gasket set
Posted: Fri Mar 01, 2019 9:58 pm
I import white silicon pushrod tube seals, R175 per set
I've had brilliant success with these
Re: Gasket set
Posted: Mon Mar 04, 2019 7:07 am
by calooker
Ditto Tony
Got genuine German Elring gasket sets R490.
Re: Gasket set
Posted: Mon Mar 04, 2019 7:33 am
by Haans
Calooker,..where did you source this Elring set?,......if I may be so bold.
Regards. Haans
Re: Gasket set
Posted: Mon Mar 04, 2019 9:21 am
by 73type2
An Elring part number would be nice.
Re: Gasket set
Posted: Mon Mar 04, 2019 9:23 am
by 73type2
Ok I googled it. Elring 009.237 Engine Full Gasket Set for 1600 engines.
Re: Gasket set
Posted: Mon Mar 04, 2019 9:25 am
by 73type2
This is the other one I saw: Elring 111198007ASP Engine Gasket Set with Crank Seal for VW Beetle
Re: Gasket set
Posted: Mon Mar 04, 2019 10:18 am
by calooker
Came from Germany via USA, no main seal.
