Gasket set
Terry Phillips
Has thanked: 193 times
Been thanked: 121 times
Zambia
Gasket set
Post by Terry Phillips »
Can someone tell me if the gasket sets for a 1600 single port is the same as the Twin Port motor.
JonnoDub
Oil Seal
Been thanked: 9 times
Re: Gasket set
Post by JonnoDub »
Terry Phillips wrote:Can someone tell me if the gasket sets for a 1600 single port is the same as the Twin Port motor.
When you buy a gasket set it has both the twinport and single port gaskets. AFAIK
Sent from my FIG-LX1 using Tapatalk
Terry Phillips
Zambia
Re: Gasket set
Thanks Jono is R228 a fair price its a decent brand.
JonnoDub
Oil Seal
Re: Gasket set
Post by JonnoDub »
Terry Phillips wrote:Thanks Jono is R228 a fair price its a decent brand.
Quite fair
Terry Phillips
Zambia
Re: Gasket set
Power Torque is that brand ok Jono sorry for all the questions.Thanks
Been thanked: 100 times
Re: Gasket set
Are the pushrod tube seals white?
Terry Phillips
Zambia
Re: Gasket set
I never asked them,are the white ones not so good.
Re: Gasket set
I saw discussions here that the white ones are recommended.
Re: Gasket set
I import white silicon pushrod tube seals, R175 per set
I've had brilliant success with these
Re: Gasket set
Ditto Tony
Got genuine German Elring gasket sets R490.
Camshaft
Been thanked: 107 times
Re: Gasket set
Post by Haans »
Calooker,..where did you source this Elring set?,......if I may be so bold.
Regards. Haans
Re: Gasket set
An Elring part number would be nice.
Re: Gasket set
Ok I googled it. Elring 009.237 Engine Full Gasket Set for 1600 engines.
Re: Gasket set
This is the other one I saw: Elring 111198007ASP Engine Gasket Set with Crank Seal for VW Beetle
Re: Gasket set
Came from Germany via USA, no main seal.
