Engine for sale- SOLD - All of it.
Get your parts here
AlbertSmuts
What model do you have?: 1970
Post by AlbertSmuts »
Good Day
I have a 1300 single port engine for sale
The motor was built by Bugger Trans
It has:
Auto linear Aluminum Case
Counter weight crank - 69mm
120 Engle Cam
New Cam followers
New bearing etc
Heads were done by Cylinder head service in Vanderbijlpark - Compress lift to 9-1
New 1,25 rockers with new push rods
Motor was balanced-crank and rods and flywheel
Empi lighten flywheel and clutch
Carb modified to suit engine RPM - 6000
It will come electronic ignition -coil, module and wiring
There is also a set of drums (Alfa brand) with new ATE pads , springs ETC
Chrome dog house with old cool tin ( no heater ducs)
Two gearboxes and a front end
Big box of Empi things
Looking for R20,000
Regards
Albert
0835100506
