Camshaft
Been thanked: 107 times
Post by Haans »
😳😳. Getting close now !!!
Been thanked: 539 times
Yes thanks Nick,
Like a little kid with a bike under the Christmas tree and you have to go to bed .......... :shock: :shock: :shock: :roll:
Just a few small things to go ..... :wink:
Just hoping to keep the team together for this final push ... :lol: :lol: :lol:
As today was the end of the weekend, we have added some things done to MeFusco
We made a few "CAD" sections to close off the open spare wheel slot, as the wheel can not be stored there do to lack of space.
We will now carry a few repair cans and repair kits, and as we have a compressor on board, this should not be too much of a problem.
This will give a small storage space for the repair kits, and maybe a bottle of oil and engine spares.
Have also made the "Kid's" bench behind the two front seats, with its location strip.
The ""VW Aircooled Type 4""badge was also fitted to the back of the passenger side of the cab
Made the CAD sections for the hood side of the dash covers and transferred this to the hardboard panels.
These are now ready to cover with the inside of the hood space.
Still messing with the front bumpers, and still have to fit the rear mud flaps.
Till then thanks for looking
Been thanked: 487 times
Seems like you are making some rather rapid progress.
It wont be long now... looking forward to seeing it on the streets
Madbones
What model do you have?: 182 Thing
Has thanked: 12 times
Post by Madbones »
This is like waiting for SpaceX SN11 to fly :D
Cant wait for the video.
Did some brake testing against engine running, and not happy with braking system..
Have decided I want to fit a T5 Brake Servo VW 7H0612101A BRAKING Regulator Master Brake Cylinder Bkv
Anybody know where I can get one at a good price
Or will have to get one off ebay
So I was convinced that my MC was too small for the 4 disk brakes fitted.
Will be looking to fit a Booster with maybe a t3, t4, or t5 MC but in the mean time wanting to get MeFusco going on the road.
So I fitted my old Bus MC and I bled the brakes.
BUT,.... I still have air in the system, and can not get a solid piston
I am sure the problem sits with the front wheels, and yes I do have the bleed screw to the top on both of the wheels.
Have tried every thing I know on bleeding brakes over the last 60 years but can not get the air out.
Will remove the bleeding screws tomorrow, and wrap them with thread sealing tape, so to make sure we not sucking air in via the threads.
If you have any suggestions, please pass them on, as the last resort will be to remove the calipers and shake the air out.
Have you tried pressure bleeding? This is there you put pressure onto the brake fluid reservoir and force the fluid through by opening the bleed valves.
Also, make sure that the fluid lines are not creating any high points that may trap air.
AlanH
Has thanked: 117 times
Been thanked: 86 times
Germany
Post by AlanH »
Herman you will probably know this already, but if you have drum brakes the shoes must be set up correctly so the y just about grip before starting to bleed. If you only have discs it obviously won't apply.
Hope you come right. BTW, I usually bleed the pressure way as Tony suggested. Makes bleeding a one man job. BUT make sure the reservoir remains full.
Wanted parts:
Left sunvisor
Sink faucet
german
Has thanked: 11 times
Been thanked: 7 times
Post by german »
Reverse bleeding, ie from the bleeding nipple back to the MC with a foot pump filled with brake fluid.
Tony Z wrote: Mon Mar 29, 2021 11:34 pm Have you tried pressure bleeding? ........
Thanks have not done it yet, but was thinking of it as most OEM's do it this way.
Will Try it. Thanks
AlanH wrote: Tue Mar 30, 2021 7:24 am .......... if you have drum brakes the shoes must .........
Thanks Alan, but yes I have disks all round, will try pressure bleed from both sides as well.
german wrote: Tue Mar 30, 2021 7:55 am Reverse bleeding, ......
Will try this way but as the fluid enters the caliper center, I am not sure it will remove the air stuck up top.
But worth a try if all else fails, Thanks
Been thanked: 100 times
Pressurizing will also show if the brake system is airtight.
[/quote]
73type2 wrote: Wed Mar 31, 2021 1:49 pm Pressurizing will also show if the brake system is airtight.
:huh:
When I got to 5 bar, Mefusco started floating .......... :shock:
Had to use ratchet strap to get him down ... :roll:
BUT .. :D ..No leaks, ... :wink:
:TIC:
:lol: :lol: :lol: :lol:
Edited ;-
Must add here that the brakes did not come up to par.
Just think the MC that we tried where to small in volume to press all the calipers.
So will be going for a 4 disk car set-up
As you guys know, the brakes where not up to my standard.
So off we went to the local MeFusco spares shop and hunted around for a suitable set-up. :roll:
Not being able to find a T5 Booster & MC, we opted for a BMW E46 Booster & MC.
Now as all these things where already in place , we would need to remove the unwanted parts,
make space for the new parts and also make adapters to make them fit into a very small space.
Now with a bit of strange words uttered, we made a adapter tube with mounting plates , bolts, and holes.
Now we just have to make space to get it all mounted.......... :shock:
So here are the parts, we will fit and report back on outcome.
Till then, Thanks for looking.
Camshaft
Post by Haans »
Think you'll have to rethink his name,.......Stoffel Fritz MeFusco ! 🙄😂🤣😂😳
