I have removed mine and bought a set. When I tried to install it it was way too thick so I returned it for a refund.
Ordered another set that was thinner and fitted nicely in the channel but the window was never going to fit inside as well. I ended up leaving it as well.
They are not cheap and I was not prepared to butcher it into fitting only to find out later it would in any case never fit.
Took a drive to Pro Rubber to see if anything was available but they close at 15h00.
On my way back home saw an Autozone and thoight I'd try my luck. Well it seems I had some luck for the day. They have a channel guide made of rubber and the felt type material inside with flaps. Fits perfect into the channel and the window is firm but not tight in the channel. Although not original this is so far the cleanest solution.
BTW. The first two were imports with a green line on the side. I have seem pictures of the same but with a red line on the side if that could be an indication?
