Page 1 of 2
Mid Engined Change over Gearlever system info needed.
Posted: Fri Oct 12, 2018 4:56 pm
Hi Guys
Anyone have the drawings for gear-lever mechanism changes to bring the gear-lever from the gearbox side to the engine side.
In other words, need to change the gear lever to mid engine format.
So the sequence will be Gear-lever - Motor - Gearbox.
Thanks in advance
Re: Mid Engined Change over Gearlever system info needed.
Posted: Fri Oct 12, 2018 7:37 pm
by jolas
What on earth are you up to now captain ?????
Posted: Fri Oct 12, 2018 7:43 pm
by buggyfan
So basically you need the setup of the gearlever as found on a formula Vee racecar or a Rsk porsche kitcar with a midmount engine
Posted: Fri Oct 12, 2018 7:46 pm
by buggyfan
Posted: Sat Oct 13, 2018 10:07 am
by Haans
You've gotmy attention Herman!
What are you up to ?
Posted: Sat Oct 13, 2018 10:11 am
by Haans
got this a while ago,,.....think its what you arelooking for
Posted: Sat Oct 13, 2018 10:22 am
buggyfan wrote: Fri Oct 12, 2018 7:43 pm
Thanks for your link, Yes that what I want to do.........
Thanks Haans
jolas wrote: Fri Oct 12, 2018 7:37 pm
Haans wrote: Sat Oct 13, 2018 10:07 am
You've got my attention Herman!
YES ...I'M Back.....
Posted: Sat Oct 13, 2018 1:13 pm
by Piet
Here is perhaps a clearer image. It is a drawing of the original Porsche Spyder/Rsr mechanism. I'm in the process to reproduce it for authenticity sake, but there are easier ways to accomplish the same
Piet
Posted: Wed Oct 17, 2018 5:04 pm
by Piet
The real thing
Piet
Posted: Fri Nov 09, 2018 8:43 am
by Haans
So !,.......is there a "sneak preview ". Available yet ?
Its too quiet to my likiing !
Posted: Fri Nov 09, 2018 10:11 am
No, Haans, This can not be done...
What I can tell you is that I have collected the following;-
Rusty Beetle Body (road side display saved)
A type 4 2lt motor in sorry state
Type 4 Gearbox in unknown state
4 Pro-white rims with 195x 80R / 14 C tyres
Renault Scenic Back axle assembly with disk brakes
Opel McPherson struts with disk brakes
Opel steering rack
Corsa Power steering wheel assembly complete
Rusty split bus rear corner units
Lots of Laser cut steel sections.
and an overhead gantry with chain block.
And ....
Well you have to wait...
Posted: Fri Nov 09, 2018 10:23 am
by 64 Notchback
To quote a line from The Rocky Horror Picture Show.
" I see you shiver with Antici.......pation"
Posted: Sat Nov 10, 2018 1:20 pm
by Haans
Ok,... I'll try andhold out.
The list is confusing,......and surprising
Posted: Sat Nov 10, 2018 2:00 pm
Haans wrote: Sat Nov 10, 2018 1:20 pm
looking at the list, my guess is one of two things...
race car of sorts - but I think that is beyond his age bracket
and he isnt going to use pro-whites on a track
so it is likely a rock crawler of sorts so he can easily cruise over Sani Pass next time.
my guesses anyway
Posted: Sat Nov 10, 2018 7:06 pm
Haha I like the way you guys think.
But no!
