Dual Circuit Master Cylinder for Beetle
Posted: Wed Aug 01, 2018 9:50 am
by 73type2
I've never had a Beetle's brakes fail on me but I'm considering changing my master cylinders to dual circuit, just for a bit of added safety. Are there any suppliers in South Africa? I'm in Cape Town.
Re: Dual Circuit Master Cylinder for Beetle
Posted: Wed Aug 01, 2018 9:56 am
by buggyfan
A common mod is to install the mastercylinder from a golf mk1.
Posted: Wed Aug 01, 2018 10:07 am
by 73type2
Thanks buggyfan. It looks like it just bolts on, with some re-orientation of steel lines, of course. I would also like to keep the reservoir in the stock position. Could this part be bought from Goldwagen?
Posted: Wed Aug 01, 2018 3:49 pm
by buggyfan
Yes, you'll be able to source a mastercylinder at Goldwagen. All you need to do is put a 30mm spacer between the Mc and the pan.
Posted: Fri Aug 03, 2018 5:56 pm
by hitlers revenge
Will that master cylinder work with all round drum brakes?
We use them when we change to front disc brakes, but as I said, not sure about 4 drums.
Posted: Fri Aug 03, 2018 6:45 pm
by buggyfan
Dont know about that HR. Just a pic I got of Fb Aircooled hooligans page.
Posted: Wed Nov 21, 2018 8:19 pm
by buggyfan
Found this while digging through the archives
viewtopic.php?f=4&t=20089#p192946
Posted: Thu Nov 22, 2018 8:20 am
by Haans
Ok ...this is also ontheto do list!!
Has anybody got a drawing /sketch of this spacer?,......can it just be aplain 30mm spacer ? OD and ID and precise length ?
Much appreciated
Posted: Fri Nov 23, 2018 4:24 pm
by splitfan
just a 30mm spacer, all you need is move the cylinder away from the "firewall" by 30mm
Posted: Fri Nov 23, 2018 5:17 pm
by Haans
I take it then there will be tweaking of the brake rod to get the correct clearance of ? 5-10mm or less?
Posted: Fri Nov 23, 2018 6:46 pm
by splitfan
Haans wrote: Fri Nov 23, 2018 5:17 pm
Correct
