spare wheel
Nick555
Has thanked: 2 times
spare wheel
Post by Nick555 »
HI Guys been a while since i have been on the forum,
Just need some advice on the spare wheel for my bug would be appreciated, the 75 beetle i have came stock with 15" wheels but i see the spare is also 15" and because of this the boot doesn't lock it latches so i can drive but it doesn't lock as i cant push it all the way down. now im not sure if the spare is meant to be a 15" if so what size tyer should i fit on the spare ? all 5 of the wheels are the stock royal style as i want to try keep it original.
thanks
Nick
Re: spare wheel
Your bonnet should lock properly with a 15in spare shod with 165R15 tyre. Wider tyres can cause issues. If it won't lock with a stock spare, then there's probably some collision damage or similar that has changed the dimensions of the spare wheel well slightly.
John Alves
Been thanked: 48 times
Re: spare wheel
Post by John Alves »
as far as I remember the latch pin is adjustable
1958 1600 TP Karmann Ghia
1968 1600 TP Beamish buggy
1968 1500 SP Beetle
Nick555
Re: spare wheel
Post by Nick555 »
HI Fig
the tyer that's currently on the spare is a 195 do you think this is the problem ?
Been thanked: 100 times
Re: spare wheel
Yes, that's your problem.
Nick555
Re: spare wheel
Post by Nick555 »
thanks il put a 165 on and see how it goes
