Aircooled VW South Africa • G-Tech Electronic igntion conversion for beetles and other points based distributors - Page 2
Page 2 of 2
Re: G-Tech Electronic igntion conversion for beetles and other points based distributors
Posted: Tue Apr 12, 2022 7:53 am
by AlanH
I think if you leave it in it is already there if you have to revert to points because the unit failed for some or other reason. Seems you would just need to refit the original cable from the dizzy to the coil.
Posted: Tue Apr 12, 2022 7:54 am
AlanH wrote: Tue Apr 12, 2022 7:53 am I think if you leave it in it is already there if you have to revert to points because the unit failed for some or other reason. Seems you would just need to refit the original cable from the dizzy to the coil.
that is my exact reasoning as to why I did it the first time.
To date, it hasnt been needed, but never say never.
