67 Single cab
Eugene
Has thanked: 59 times
Been thanked: 65 times
67 Single cab
Post by Eugene »
Ok, maybe in the wrong section as this will not be a restoration project but neither will it be a Sean like, weekend wonder :wink:
So let me officially introduce the the car. He has no name(yet) but is most definitely a he...bakkies just are.
AlanH
Has thanked: 126 times
Been thanked: 86 times
Germany
Re: 67 Single cab
Post by AlanH »
Congrats.
Wanted parts:
Left sunvisor
Sink faucet
Eugene
Re: 67 Single cab
Post by Eugene »
As per the subject line, it is a 1967 Single cab. It has been in one family since new. It has always been a "plaas bakkie" and was only ever registered on the road, for the first time in 1994 by the now, previous owner and grandson of the original owner. It is a 50 year old, unmolested work horse, now retired. As I said, I will not restore it but keep it as is and do my best to retard the natural ageing process. Also fix the current issues, like fuel tank and fuel lines, fuel pump, brakes and steering. The engine was running but due to rusty, very crusty fuel tank, the fuel lines were blocked, fuel tank leaking and fuel pump faulty.....all related I believe. The PO then fitted an electric fuel pump and ran it off a fuel can :shock:
Eugene
Re: 67 Single cab
Post by Eugene »
The fuel issues were all caused by this. Water and dirt enters this area...accumulates over time causing rust.
The tank was shot, with so much shit inside, I thought it was half full of fuel. Once the covers and tank was removed, the consequences of the small opening left unattended was clear :(
This all came out
Unfortunately, I did not take "after" pics but the area was cleaned, vacuumed and then treated with rust converter. The load bed will be welded closed again to prevent a repeat.
Eugene
Re: 67 Single cab
Post by Eugene »
In the mean time, I fitted a new fuel pump and got rid of the electrical pump and incorrect diameter fuel line. Unfortunately, the old metal line is so blocked, I could not even clear it with compressed air, so I will replace that as well. With the new fuel pump in place, the little engine starts up immediately and purrs like a kitten. Unfortunately, the exhaust is also moertoe and will be looking for a replacement.
https://youtu.be/gYx9OT2ea80
Donovan D
Has thanked: 148 times
Been thanked: 73 times
Re: 67 Single cab
Post by Donovan D »
Lekker Eugene !! Is die fuel lyn wat jy kort vanaf die pomp na die carb ?
Eugene
Re: 67 Single cab
Post by Eugene »
Nee, tussen die tenk en die engine bay
freddiebooysen
What model do you have?: 1972
Been thanked: 47 times
Re: 67 Single cab
Post by freddiebooysen »
Hehe lyk goed man.
Re: 67 Single cab
Eugene wrote: Wed Nov 01, 2017 2:47 pm Ok, maybe in the wrong section as this will not be a restoration project but neither will it be a Sean like, weekend wonder :wink:
You will pay anything to get something safe to stand on to look over the fence........... :shock:
Nice buy, good luck with the stepladder....... sorry ... should read Van.... now where is the erase button again..... :roll:
:mrgreen:
sean
Has thanked: 63 times
Been thanked: 227 times
Re: 67 Single cab
Post by sean »
Hey Uncle
Pay attention, forget about granny ghia on the other side of that wall.
Yours is easy. I think I took a entire 2 weekends to get this one rolling.
But I think we can allow an extension until Feb, George 2018. Then you can roll with these 2.
I crave a road trip in a patina bus again.
Eugene
Re: 67 Single cab
Post by Eugene »
sean wrote: Wed Nov 01, 2017 9:36 pm Yours is easy. I think I took a entire 2 weekends to get this one rolling.
How do I block this guy :twisted:
sean
Re: 67 Single cab
Post by sean »
Eugene wrote: Wed Nov 01, 2017 10:03 pm
:shock: :lol:
Nice single cab by the way.
Re: 67 Single cab
Now I thought you wanted to take your Autovilla to George after last year's rained out affair, leaking tents and all ???
You could also use your nice Jurgens teapot and cups and saucers.
Very nice single cab Eugene !!!!
sean
Re: 67 Single cab
Post by sean »
jolas wrote: Thu Nov 02, 2017 12:49 pm Now I thought you wanted to take your Autovilla to George after last year's rained out affair, leaking tents and all ???
Yes, correct sir, never again will I sleep in a tent. I will take the patina busses and I'll just make sure that my other half takes an autovilla. Then I can sleep comfortably and have dinner off all that superior Jurgens crockery.
JC Rousseau
What model do you have?: 69,75split,75,79scab
Has thanked: 85 times
Been thanked: 16 times
Re: 67 Single cab
Post by JC Rousseau »
Lekker wa daai Eugene :hangloose: :flash:
61 Beetle aka klapperkiste
68 Squareback viewtopic.php?f=23&t=34408
69 Kombi
72 Crew cab viewtopic.php?f=23&t=32846&hilit=1972+custom
75 Fleetline panel viewtopic.php?f=23&t=32485&p=309053#p309053
79 Single cab
