Weak headlights
Posted: Tue Sep 19, 2017 7:39 pm
by Kombikoors
Hi all
I just don't understand what this problem is anymore and i have been battling with it for more than a year already. I wasn't very happy with my kombi's lights and the i went the golf route. I have replaced the standard 72 baywindow headlights with vw golf crystal 55 watt headlights with 1 x 40 amp relay to run the both dim's on the headlights and 1 x 40 amp relay to run the brights on both headlights. I have replaced all the wiring from the lights to the relays and then to the light switches but the light are still as weak as the original lights.
Please help. What am i doing wrong
Thank you
Re: Weak headlights
Posted: Tue Sep 19, 2017 9:14 pm
by sean
Hi Kombikoors.
I would advise you to first start removing these golf crystal headlights and relays you speak of, most probably all made in China. Revert back to original and find the source of the problem.
1 - Dim globes are often caused by bad earths and weak connections. The thickness of the original wire is more than substantial and no additional relays are needed. Check the condition of the original reflector. If there is discoloration and rust, you must have these re-chromed.
2. Are your headlights aimed correctly? This is very critical to have a clear view, just slightly adjusted out, up or down and it will limit your vision substantially.
Re: Weak headlights
Posted: Wed Sep 20, 2017 10:01 am
Have a look at the head light 3 pin plug, this has been wired or re-wired incorrect, you are getting both filaments burning at the same time.
Test the lamp with a battery, 1st two points, note which filament lights up, if both, move one wire.note which two pins you have, then move your two wires to different pins and find the other filament, now you will know which pin is common on both filaments.
This common pin is your earth, make sure your plug has this pin as earth by tracing wire and ensuring the point that it is fixed to in clean, remove sandpaper, both sides of the lug, fit a new washer, and tighten, cover connection with grease or spray paint.
Now the other two pins will be your dim and bright, thats easy to find which is witch.
I find that the OEM Golf semi sealed beam gives better light then a re-chromed reflector, only my opinion.
Good luck
Re: Weak headlights
Posted: Wed Sep 20, 2017 11:43 am
by Dawie
If you happen to have those down-hanging aftermarket "eyebrows", remember that they block half of the dim beam and a quarter of the bright beam.
I did test those "crystal light" replacements and they were inferior to standard Hella ones. Especially the cutoff in dim mode... it was shining up into oncoming traffic's eyes in the shape of lines/dots in certain positions.
Re: Weak headlights
Posted: Tue Apr 03, 2018 6:32 pm
by Kombikoors
Thanks for all the positive info. Will let you know what the outcome is
Happy travels
