SC Fleetline Splitty
Posted: Wed Feb 01, 2017 9:01 pm
HI guys
Thought I would start this tread to post some pics of my SC Fleetline I bought from a fellow forum member Dsan a couple of Years ago
At the Time He bought it I had it in my mind that he was Crazy as the Bus looked like shit and rusted
I bought the bus about 4 Years ago already and by the Time I bought the Bus I actually then thought What a lekker nice Bus with very little
sheet metal work to be done as I have by then Built a SPlit bus or 2 with some serious sheetmetal work needed
I actually bought a small scale sc splitty and painted the bus that colors
Once it was painted I was not happy with the Paint Quality and then aswell the Darker color top with lighter color Bottom did not do it for me
I there and then Decided I want to have it painted b our other Panel Beater that normally do the Higher and better Quality Paint finishes
I ask around on Face book etc for color sugestions and eventually I decided on the Same Colors as my Karmann Ghia
Light lime Greem Botom and Beige top
I have organized a Samba DElux trim kit made specially for a Single Cab Split Window Bus
Wheels I am going to use is a set of BRM 15"
Will most Probably fit a set of Safari Windows to the Bus
Motor wise I am still hanging in the Air
I got a few choices
2.4 Type 4 Upright twin Carbs
2L type 4 Upright twin Std single choke Carbs
2020cc Type 1 twin Weber or DEllorto carbs nice new Chrome tinware (Still building this motor need to assemble all machining is done)
std 1600 Type 1 Full recon motor with C25 cam and std Carb just to have a casual croozer
Gearbox wise I will Obviously do a late model Recon Bugger
Box with might go longer 4th gear
Will Post some Pics later from my Cell
Thanks for Readig
I got a few choices
Thanks for Readig
