Fitting a 2L golf motor in a 2.1 Caravelle
Hey guys. I'm busy fitting a 2L golf motor in a 2.1 Caravelle. The problem I'm having is hight under the engine cover as the carb is to high. Anyone with suggestions?
- splitfan
- Has thanked: 46 times
- Been thanked: 26 times
Re: Fitting a 2L golf motor in a 2.1 Caravelle
You have to get the extended cover used on the 5 cyl busses for the intake/carb to clear if you fit the Golf motor . VW still sold them new (about a year ago) or get one from your local scrappy they are just spot welded on and you use your existing lid.
Tought as much. Thanx for the info. Think i'll bould it myself to save costs
