Hi guys. I'd like to share with you my current project and introduce myself as I'm new on ACVWSA. My name is Alexander and I'm a second year diesel apprentice at a reputable tractor company. My ride. Well his name is Mossie, a family heirloom, one which my father considered scrapping or stripping as it was left under a tree in the wind and weather for a few years.
As I love the car I refused to let him die and decided to take it up as a project also modifying it to my own tastes. Currently it's basically stock standard and I've only gotten it back on the road. I've been stacking up parts for the last few months, including a proper 4 into 1 stainless system, 40 Dellorto sidedraft, golf distributor and coil, a second beam and empi SAW style adjusters. Also having a set of rostyles made up which will be 30 & 50mm wider on a 3 inch narrowed beam. Over time I'd like to get the rust repaired and return it to it's standard glory. But for the time being, I'll do what it looks quite a few people forgot. Enjoy it for what it is while I can.
Sent from my ALE-L02 using Tapatalk
1978 Volkswagen 1600S
Re: 1978 Volkswagen 1600S
Welcome, good to see your project.
Looking very good.
You have made a lot of progress already, will be good to see when you done.
Looking very good.
Welcome to the forum
Project is looking good so far.
The golf dizzy will lead to a very unhappy engine - there has been plenty written about it on this forum, basically the advance is all wrong for the bug.
Keep us posted on your progress, I am sure we all want to see it happen!
- What model do you have?: 1969 VW 1600 Baja
My dad fitted the roof rack this morning as I'm not at home during the week.
Thanks a lot Tony and Retrovan. I haven't read any of your threads yet Retrovan, BUT I have read all about ANGERR. Was it two or three R's?
Anyway is the golf distributor the same as the 009 as I avoided that for the flat spot? The only reason I went with golf was due to availability and being popular and easily modified to our pickups etc. I only recently discovered the Accuspark setups available from German Steel Toyz. As I'm planning on having a set of heads done sometime I want electronic as to not worry about the higher rev range. With all honesty, my current standard points and condenser setup is spot on so I can't really justify replacing it.
The very guilty sidedraft.
