sweet conversion
Has thanked: 36 times
Been thanked: 50 times
sweet conversion
Post by flatfourfan »
I wish that scooby motors were cheaper to buy and maintain in SA.
Amazing work and detail on this ride.
http://radiumauto.com/media/blog.php?da ... te_month=7
chopwet
What model do you have?: Ex: Type-1 WBX
Re: sweet conversion
Post by chopwet »
That's an amazing car, perfect in every sense although the wing is needed it would be perfection without it.
Subaru motors can be bought for less than R7000 from importers, that's really not that much money for a 200hp motor.
Been thanked: 487 times
chopwet wrote: Subaru motors can be bought for less than R7000 from importers, that's really not that much money for a 200hp motor.
Yip, then you have an engine on the floor. Only then does the spending start.
Thats another topic, hijack over...
engines are cheap.
adapter plate
sump kit
ecu and wiring harness
exhaust
service kit
OEM clutch kit, because you don't get pirate scooby parts in SA.
Then you'll have to do the gearbox, brakes and suspension.
R80 000 - R100 000 for a basic solid conversion.
chopwet
Post by chopwet »
flatfourfan wrote:engines are cheap.
adapter plate
sump kit
exhaust
service kit
Yes of course all of the above is very true but the same goes for all modifications and conversions. As a Subaru owner I know very well the limited amount of parts sources available.
I would guess that getting the same amount of power reliably out of a AC motor will cost at least that much. Nevertheless that is an awesome car.
It's a pity that the older single cam Subaru motors aren't readily available here. One of those with some carbs on it would be ideal.
That's the truth, on all counts.
