sweet conversion
Posted: Fri May 30, 2014 1:07 pm
by flatfourfan
I wish that scooby motors were cheaper to buy and maintain in SA.
Amazing work and detail on this ride.
http://radiumauto.com/media/blog.php?da ... te_month=7
Re: sweet conversion
Posted: Thu Jun 05, 2014 10:26 pm
by chopwet
That's an amazing car, perfect in every sense although the wing is needed it would be perfection without it.
Subaru motors can be bought for less than R7000 from importers, that's really not that much money for a 200hp motor.
Posted: Fri Jun 06, 2014 7:25 am
chopwet wrote: Subaru motors can be bought for less than R7000 from importers, that's really not that much money for a 200hp motor.
Yip, then you have an engine on the floor. Only then does the spending start.
Thats another topic, hijack over...
Posted: Fri Jun 06, 2014 9:58 am
by flatfourfan
engines are cheap.
adapter plate
sump kit
ecu and wiring harness
exhaust
service kit
OEM clutch kit, because you don't get pirate scooby parts in SA.
Then you'll have to do the gearbox, brakes and suspension.
R80 000 - R100 000 for a basic solid conversion.
Posted: Wed Jun 18, 2014 2:48 pm
by chopwet
flatfourfan wrote:engines are cheap.
adapter plate
sump kit
exhaust
service kit
Yes of course all of the above is very true but the same goes for all modifications and conversions. As a Subaru owner I know very well the limited amount of parts sources available.
I would guess that getting the same amount of power reliably out of a AC motor will cost at least that much. Nevertheless that is an awesome car.
It's a pity that the older single cam Subaru motors aren't readily available here. One of those with some carbs on it would be ideal.
Posted: Thu Jun 19, 2014 7:39 am
by flatfourfan
That's the truth, on all counts.
