Motoring along SWIFTLY....
I found this thread on the Samba, hopefully no negativity will come from sharing this, as I think it's a A t Z of engine rebuilding, (WITH PICTURES) for us dom, practical ouens.
http://www.thesamba.com/vw/forum/viewto ... d882be1540
So, flew to Shelleys at lunch, got a 2nd hand new air cooler, which is for sure not holed. Cleaned it up, and using "Glue Devil Greypremium performance gasket maker", I put the two oil seals back, and bolted it up. Looks good.
Also dropped in at FFR on my way home, picked up a new Sieve and heavy duty, thick round sump plate. VERY nice stuff.. Cannot believe how butchered my old round plate and sieve was. No wonder the car leaked. So they're in the bin.
Put the paper gaskets on with the grey gunk, and managed to eventually get this whole lot onto those 6 bolts straight, without damaging anything.. You need to understand the motor is currently sitting on top of two cinder blocks, so my room to work in, is approx 20 cm's.. urgh.. Eventually got the 6 nuts on with the supplied crush washers, and tightened up. Have grey stuff well sealing the entire surround of the plate. If this leaks oil, then fukit.
Also got the fuel pump on and oil pump plate with similar, positive results. I guess time will tell, but for now, it's looking clean and neat.
I also set the valve clearances on the new heads, in prep to close up the tappet covers. All seems spot on. I LOVE my Aluminium Pulley with red signage on, looks awesome, and certainly will be straighter and more acurate than the original POS I hammered off.
So, gonna fit the covers, and the rear tin, and then I think, we're going back in. I will assemble all the other tin and parts from the engine bay.
Oh, also cleaning up the engine bay so it's all black, and clean. There's a complete piece of rubber whick mounts onto the lip in that engine bay and sits ontop of the engine tin, and makes a very good seal to separate the hot air under from the cool air on the top. Time will tell..
