multiple aircooled
Re: multiple aircooled
and dont forget about the damn fuel filter in the engine bay, just above a source of sparks and heat...
- beetle786
- Camshaft
- What model do you have?: 1968 + 1303
heard guys moving it to the underside of the left rear fender .should be safer .Tony Z wrote:and dont forget about the damn fuel filter in the engine bay, just above a source of sparks and heat...
as long as you change the position of the fuel filter you should be fine move mine to the left on the side .
i move my coil fitted it on the left of the air shroud.
left hand side fender???? Move it to next to the gearbox where it is supposed to be. Its just harder to change there
- beetle786
- Camshaft
maybe i was mistaken some thing of that sortTony Z wrote:left hand side fender???? Move it to next to the gearbox where it is supposed to be. Its just harder to change there
