http://www.rallyracingnews.com/teams/villemure-vw.jpg
TECHNICAL SPECIFICATIONS Wheelbase
Weight 59w x 96
2250 lb
Engine - Air Cooled
Aspirated------>
Volkswagen: pushrod, 4 cylinders, 2750cc
Autocraft 910 heads, 15 qts dry sump
NO-overhead cam, NO-turbocharger, NO-traction control
Horsepower
Torque
Max rpm 200 hp @ 4500 rpm
210 ft-lb @ 4800 rpm
7000 rpm
Engine Management System
Carburetors
Spark Plugs
Engine Oil Cooler
Engine Lubricant
Air Filter MSD Ignition
(2) 48 IDF Weber
NGK
3 - front mounted, inside compartment, and tail end
Valvoline Racing 20W50
K&N
Transmission Competition by Transform
4 speeds, fully synchronized, close ratio 4.86:1
Clutch 4 puck disc - 3000 lbs Kennedy
Fuel Cell
Fuel Pump (2)
Fuel Fuel Safe - 20 gal.
Carter electric
VP 112 octane
Front/Rear Brakes
Master Cylinder
Brake/Clutch Fluid Wildwood dual piston caliper
Neal
High temp.
Front/Rear Suspension
CV Joints FOX Shox - Nitrogen filled
Sway-Away axle
Steering Rack & Pinion
Steering Wheel Wright Place
Tilted & quick disconnect
Wheels
Tires 7X15 - Centerline
Michelin
Rollcage
Seats
Seat Harnesses SCCA approved
Beard Seat
Quick disconnect - 5 points harness
Instruments
Alternator
Lights
Navigator's Odometer
Intercom VDO
Porche - Bosch 70 amps
(2) Cibie - (4) PIAA
TerraTrip 404
Peltor Communications
Villemure Racing's 1972 VW Beetle Group 5 - Rally Car
- Thumper
- Has thanked: 6 times
Cool! I want, no, need one of those!!!
