Hi all
I'm thinking of adding a oil temp sensor to my newly acquired 1600 (fresh build from Calooker) motor
Is it worth it, or am I wasting time and money?
Oil temp sensor and gauge
- John Alves
- Has thanked: 3 times
- Been thanked: 48 times
1958 1600 TP Karmann Ghia
1968 1600 TP Beamish buggy
1968 1500 SP Beetle
1968 1500 SP Beetle
- Been thanked: 98 times
Re: Oil temp sensor and gauge
I hate guages, they make me worry too much.
Thats true. But sometimes it is needed.calooker wrote:I hate guages, they make me worry too much.
I wouldnt bother with the temp sensor on a 1600 if you dont go racing. Check the temp of the dipstick occasionally until you are happy it is OK.
If you burn yourself, oil is too hot (can happen when the engine is running in). If you can hold the dipstick for a second or more, then temp if OK.
When I have had work done on a VW motor, I used a long glass thermometer, into the dip stick hole for the 1st week, to see the temp of the engine.
When happy, its running right, I replace it back with the dip stick.
Now I have a temp. logger with two sensors, so now I am really Posh.
(had to get one for my work)
But whats good for the cats a$h, is also good for the VW motor....
- Batman
- What model do you have?: 1971 Beetle 1600 TP
- Has thanked: 4 times
Tony Z wrote: Wed Mar 13, 2013 12:57 pmIf you can hold the dipstick for a second or more, then temp if OK.calooker wrote:I hate guages, they make me worry too much.
While I'm driving ..... asking for a friend
- Has thanked: 141 times
- Been thanked: 100 times
Herman!! What are you doing to your cat?? Should I call the SPCA on you??
