electronic ignition
- What model do you have?: 1974 beach buggy
- Has thanked: 2 times
electronic ignition
ive been toying with the idea for a long time to get electronic ignition, so I could get rid of the points, condensors and tempramental crap. I looked at a distributor on a chico, and it looked very similar to a 009. So I sourced a chico dizzy, took at apart and transferred the electronic stuff over to the 009. I had to drill 2 new holes, swop the top of the shafts and cut a slit for the electric male connector and a few other minor spares. Everything sems to fit extremely well. I got a quote from Goldwagen for a wiring harness and ignition module. Total cost is round R 260.00 and I can even keep my current coil ( according to the dude at goldwagen)
Im sure its nothing new, Does anyone have experience of this mod.??? Wanna try it out tomorrow
- Has thanked: 191 times
Re: electronic ignition
have not done that mod yourself, but if you are basically running a chico setup then you need a chico coil.
Electronic ignitions and points ignitions use different type of coils.
- buggyfan
- Long Block
- Has thanked: 95 times
- Been thanked: 87 times
scrappy wrote:Im sure its nothing new, Does anyone have experience of this mod.??? Wanna try it out tomorrow
http://www.aircooledvwsa.co.za/viewtopi ... 84#p226651
- Chucker02
- Facebook: chattingh74@gmail.com
Did the exact same thing on my beetle 3 and a half years ago. works like a charm! you will need the electronic coil though. i have never had any isues with mine.
- swiggs
- What model do you have?: 1969 Beetle 1641cc
- Has thanked: 4 times
Same here, did the conversion in the beginning of the year and never had issues. Car starts, idles better and seems more responsive. Just my 50c worth.
Thank you guys, Just proves that there is nothing new under the sun- Amazing though to think that the dizzy used in the 1.4 chico still for sale is basically the same( except for the shaft) as the dizzy designed way back and used in the beetle. Good to hear im heading in the right direction. Fitted it today and confirming thepolarity before switching on and startup
regards
regards
- What model do you have?: 1974 jeep
Hi
I am looking to do something similar. Want some advise please.
Can I use a golf 1 dizzy(with vacuum advance) and modify the piece that goes into the engine and keep the rest standard. Then buy the coil that goes with the dizzy.
Will something like this work and is it possible. I did read of people that have done something like this but can not find much detail on the mod itself.
Riaan
Riaan
- VW-rules
- What model do you have?: '61 & '70 Buses
- Has thanked: 10 times
Qickest, simplest, cheapest solution
http://www.accuspark.co.uk
R540.00 from Steve Woodward <woodward@icon.co.za> in Cape Town (Their agent as per the website)
Product code JFU4
Product code JFU4
- What model do you have?: 75 bug
I do the same mod on most of my customers cars works beautifully still uses the original coil.
Aircooled Baby
- VW1600S
- What model do you have?: 69-1500/72-1600/
- Been thanked: 2 times
The old Alfas 33 have a bosch dist. and it's just a drop in swap, I cut the side plate off mine and sanded that area down to look stock, had to use the coil which is also Bosch! All worked lekker till an exhaust valve broke (still had the vw part nº on) and stuffed up the head and the piston) My 69 1500 was working like a Swiss clock
- John Alves
- Has thanked: 3 times
- Been thanked: 48 times
I've done both the golf conversion as well as acuspark no issues on both
Acuspark is quick and very easy
1958 1600 TP Karmann Ghia
1968 1600 TP Beamish buggy
1968 1500 SP Beetle
1968 1500 SP Beetle
- What model do you have?: 1978
Im using the accufire module and its worked good so far.
Green 78 Westfalia Helsinki,
2056 with 41 x 34 valves,ported heads
Fully balanced
8,5:1CR
JPM Custom made cam
JPM 7075 dual taper pushrods
IDF 40's with 28mm venturi's
Phyton CSP 42mm exhaust.
Accufire electronic ignition.
115HP (dyno)
Fully balanced
8,5:1CR
JPM Custom made cam
115HP (dyno)
