Manifolds
Manifolds
IMPI
Can your jigs for the 36 IDF manifold be adapted to make 44mm IDF versions?
It would make an ITB conversion easier
IMPI
What model do you have?: sp2
Been thanked: 78 times
Post by IMPI »
I will need a drawing of the base but it is possible
hoogop
What model do you have?: 1975 Beelte
Re: Manifolds
Post by hoogop »
Hi IMPI,
Do i understand correct? You make manifols to fit 36-44 idf's?
Is this center mounted or one on each side?
I'm interested in either or
Regards
Re: Manifolds
Dual carb setup
IMPI
Re: Manifolds
Post by IMPI »
Hi tghese manifolds are for type 4 engines made from steel.And will not fit beetle type 1 engines.
Re: Manifolds
How much for a set of these IMPI? Are you able to make them like eben's for a type 3?
