Tyre size calculator
Posted: Wed Dec 07, 2011 8:04 pm
by Pine
This might come in handy whenever it is needed! Enter the stock tyre, and new tyre dimensions, and see what will happen to your speedo reading
http://www.miata.net/garage/tirecalc.html
Re: Tyre size calculator
Posted: Thu Dec 08, 2011 3:25 pm
by riaanj
That's really handy.. Thanx Pine!
Posted: Thu Dec 08, 2011 3:42 pm
I found that one a while back.... by far the best one I have seen online
now, what size is stock?
Posted: Tue Dec 13, 2011 2:58 pm
by riaanj
Tony Z wrote:I found that one a while back.... by far the best one I have seen online
I would like to know what size a stock tire is too, or what it would be with the modern equivalent..
Posted: Tue Dec 13, 2011 3:25 pm
by Pine
Stock Beetle tyre is 165/80R15
Posted: Thu Dec 15, 2011 1:09 pm
by riaanj
Pine wrote:Stock Beetle tyre is 165/80R15
Sweet thanx..
Posted: Thu Jul 11, 2019 8:10 am
by Donovan D
A bit more visual -
https://tiresize.com/tyre-size-calculator/
I know this has been covered but cant find the post.
Can I use two different sized tyres on the rear ? Currently I have 195/65/15 both sides.
Bought a 195/65/15 as spare and had it fitted to an original split rim. Last night I checked if the wheel would fit and if I had the correct length wheel bolts. The tyre is up against the spring plate and cant turn. I was thinking of getting a 165/80/15(which I cant seem to find) and fitting it to a beetle rim to use as spare wheel to clear the spring plate.
But this would mean I will have two different size wheels on the gearbox. Can I do this ?
Posted: Thu Jul 11, 2019 10:21 am
by Riaan.N
According to the website you posted its only a 1.6% difference. It’s so small and I doubt it would cause any problems. The diff should allow for the differences in wheel speed.
My spare is 175/65/15 and all the others are 185/65/15...that’s a 2 % difference. A 185 doesn’t fit very well in the spare wheel well, that’s why I went with a 175.
Posted: Thu Jul 11, 2019 11:01 am
I have a Smart car tyre on my VW rim as a spare for my Fastback as well as the Fleetline.
They just fit better into the spare wheel well and allows for more tools.
As it is a spare, you not going to ride 1000s Km on it, so it will not matter.
It the same as riding on your rim when you have a flat.
no problem.
But that said, I would not have that for anything other then emergency.
Posted: Thu Jul 11, 2019 12:15 pm
I agree with the guys above too.
It'll be fine as a spare. But use it as a spare to get you somewhere to fix the original tyre.
Posted: Thu Jul 11, 2019 2:29 pm
If you are doing a long distance trek and have to replace the rear tyre with the smaller spare, you could consider putting the spare on the front and putting the front tyre on the back to replace the flat. Assuming your tyres are the same dia front and rear
Posted: Thu Jul 11, 2019 2:38 pm
by Donovan D
Tony Z wrote: Thu Jul 11, 2019 2:29 pm
Planning on doing a long distance trip - check gumtree for sale section over the weekend, that would be a good indication whether I made it
Front is 195/50/15. I bought two tyres as spare one for the front and one rear. Had them fitted on the original kombi rims.
Idea was to swop and change as needed, move both fronts to rear if needed etc. Im getting the 165/80/15 later today and also moving the other tyres over to beetle rims, seems they have a bit more clearance from the springplate. If that does not work I can just return the tyres for a refund and have the 165/80/15 as spare, after the trip.
Posted: Thu Jul 11, 2019 3:14 pm
good luck - remember the trip report!!
