Fleetline with Zoom complete strip down
Posted: Fri Sep 30, 2011 11:33 pm
Thought I will do a short thread of the 15 window Fleetline that I am fitting a 13Bt Mazda Rotary motor in
This bus was bought By Mike a Guy I met at the Rand Easter Show when We were doing marketing for the Logo day
When He bought it a Golf motor was already fitted to the Bus but what a
job
The bus was at a custom shop and he was not happy with some of the progress
A Set of Wilwood brake kit was fitted but not the Ideal way it was 5x205 Pcd with Adapters to 4x100 that brought the front wheels outwards allot so not much room for lowering the Bus
The back the bus was dropped slightly and the front the Guys removed torsion-bars to lower it slightly
This is how I got the Bus
I did a Run or 2 with the bus while I was getting some of the Ducks in a row to do some lowering on the Bus with the Straight Axle conversion I was Buzy with
In the meantime Mike wanted me to build him a 2L 16V Turbo Golf motor but Talked him out of it and rather a Rotary
One of my Favorites.
The straight Axle kit took a while longer as planned But I finally got the First set build and on This bus so I can have wheel alignment checked and all relevant spacing clearance between the Adjusters and the Rims and Tyres
I have Built one of my Stage 1 Transmissions for the Fleetline that I have fitted with the Straight Axle conversion to handel all the power
The motor was in a Friends Bug that had a slight mishap I bought the motor and we stripped it and fitted new 3mm seals as the Rotors was machined to take 3mm seals and the motor was Ported already before
so all it needed was a upgrade Turbo which I also had waiting for the project to take speed
I have so far Fitted the Stage 1 trans with Straight Axle kit . and the Motor and the Radiator at the Bottom of the Bus in between the Chassis Legs which was no easy Task
Bought Today the Charge Cooler
Charge cooler Reservoir tank
EFI COmputer for Managing the Fuel and Spark
16" Flat fan on the Radiator
Surge tank for fuel
EFI Pump and surge tank pump
Will load some pics as I did take some but not down loaded yet
Surge tank for fuel
