I am building this Baja Jetta from a 86 4 door Jetta sitting on a 78 Bus chassis with Bus 6 rib and Jetta diesel in back. I have a set of wide Fuchs with off-road tires. As the photo shows, there is still alot of work to be done. The body is mounted using factory suspension mounting points.
