My 63 VW Transporter Kombi Project
wimvil
What model do you have?: 1960
Facebook: http://www.facebook.com/media/set/?set=a.1715319973393.
Post by wimvil »
I found in the bush and post my photos on facebook on this link :hangloose: http://www.facebook.com/media/set/?set= ... f863f3bc62
Donovan D
Has thanked: 148 times
Been thanked: 73 times
Re: My 63 VW Transporter Kombi Project
Post by Donovan D »
Goodluck with the resto.
Strange that the whole kombi is stripped but the front badge is still on it, thats usually one of the first things to go.
wimvil
Post by wimvil »
Splitz wrote:Goodluck with the resto.
They took all the shiny stuff and left the rest, probably dont know the value of it
looks like a huge undertaking!! Good luck to you and keep us posted on your progress.
wimvil
Post by wimvil »
Tony Z wrote:looks like a huge undertaking!! Good luck to you and keep us posted on your progress.
will do i looked under the chassis numbers and it is actually a 1960 model :D
bugspray
Floorpan
Has thanked: 24 times
Been thanked: 16 times
Post by bugspray »
Duuuude! You Crazy!! Exactly how we like them! You gonna fit right in. Good luck with this one. What's the plan for it?
:shock: You ARE brave :hangloose: Keep us updated with your project :D
wimvil
Post by wimvil »
i dont know if i must tell you about the future of this van it is after all the Aircooled vw web, but here it goes. the body will stay 100% original on the outside and in the cab, for the undercarrage this is where the manure hits the fan. Unlike my H 100 Hyundai with a v8 lexus in it the kombi is getting a new handbuild chassis with an A arm front suspention and independent rear axle, and yes this is what makes it different and will most probably be the only one of its kind. The motor, gearbox will be from a toyota supra 2JZ 3.0 twin turbo fitted in the close centre with a 3.7 ratio bmw limit slip rear suspention. So basically only the body will be standard with a complete new chassis bolted underneth and yes it can be done. We just completed a lada niva that used to be 4x4 and replaced all parts under the body. it is also running a 2JZ 3.0 supre twin turbo, we just completed the exhaust and propshaft. Completeing interior. it is a 2x4 now, will post some picks later
Mooi man
Do you ride in the Primrose/ Benrose area sometimes with the H1 with the V8 I have seen it a few times unless there are more than one
When I saw the pictures of the floor gone I thought you got lots of patience and time but the space chassis will be much cheaper and mor fun :hangloose:
Where / what area is the bus atm
bugspray
Floorpan
Post by bugspray »
And it gets Crazier!!!
wimvil
Post by wimvil »
There are more H100s but with 350 chevys, i also had one in mine but they are crappy so i did a lexus convertion . My H100 is a new model and i am in Centurion. This is the link to the Ladas Photos http://www.facebook.com/media/set/?set= ... c25a2114f2
HEHEHe my Boet se Karretjie
Looks good the installation nice job well done what is the wheel size on the lada ?
wimvil
Post by wimvil »
Bugger wrote:HEHEHe my Boet se Karretjie
254/50/19 made to fit a bmw 5/120 pcd
Nice
The wheels and arches are nicely matched
The lada already looks fast standing still
The suspension you are going to use on your Project is it locally drawn or is it one of the imported plans ?
wimvil
Post by wimvil »
wherabout is your shop i see you do some adapterplates and stuff
