Page 1 of 21
Retrovan's 1968 Fastback
Posted: Wed Mar 16, 2011 6:41 pm
Edited ;- New name of thread is;-
Retrovan's 68 Fastback,
...........Old name of thread was;- Not 1967 but 1968 Fastback now with twin weber 2000cc motor
EDITED:- Removed FI, and now fitted twin 34 ICT Webers to the 2000cc type 4 motor
Hi All,
Have received my Fasty, by Road transport today, did not want to tow it 1000Km, (why kill it before its home)
Have started stripping it for prep. ready for spray.
Have stripped all panels, and found lot of surface rust, but no holes.
Will be taking it right down to base metal, e-coating all parts, and repainting it back to RED
Car was colour code 12 (think black) (or white) then Red and now back to RED
Have pic's but cannot up load them yet (too Thick)
but we will work this out. (maybe ask Blitz )
Re: 1967 Fastback with type 4 FI motor
Posted: Wed Mar 16, 2011 7:51 pm
by jolas
Hey congrats on the Fastback, good luck with the project, please post pics as you go ................
Posted: Wed Mar 16, 2011 10:44 pm
by Blitzkrieg
Can't go wrong with a Type 4 in a Fasty...
12 would be black originally.
Mail me the pics and I'll upload them for you
Posted: Wed Mar 16, 2011 10:51 pm
by karmakoma
Sounds interesting! Yes please, PICS!
Posted: Thu Mar 17, 2011 7:11 am
by Bugger
Did you buy it with the type 4 motor or are you going to fit it yourself?
Pics Pls
Posted: Thu Mar 17, 2011 7:47 pm
Hi ALL,
JOLAS ;- Thanks,
Karmakoma;- Thanks,
Bugger;- Got the fasty , without engine , and then got the engine, with wiring and computor for injection, still do not know if it works, but that is for an other day.
Blitz;- thanks for the offer to post pic's, have e-maild to you. Thanks again.
To update, I have striped all carpets, padding, sound proofing out of the car, and now found rust holes.
But have also found a 1972 1/2 cent , this will reduce the cost already.
Found a lot of water under the sound proofing, this has been there for years, Note to self;- Make sure all window rubbers are water tight.
Will be sending seats for upholstry (white) and redoing the carpets (Black)
All loose panels and bits will be sent out for paint striping, e-coating and repainting.
Will be spending most nights wire brushing rust, covering with "Rust Converter" and priming the next day.
Till next time.
Posted: Thu Mar 17, 2011 9:43 pm
by Blitzkrieg
Posted: Thu Mar 17, 2011 9:49 pm
by karmakoma
That does not look too bad at all, I have definately seen worse
Posted: Fri Mar 18, 2011 8:45 am
by Pine
Is that my old Fasty??
1. I bought/sold it in Bloemfontein
2. It was factory black, with a red respray and white/grey interior
3. It was traded to 69Bug in 2005, and I believe it ended up at Volksieshop?
(I never actually drove the Fasty, had plans to restore it, but had to move to GP - Note HW1 in the background
This is the day I fetched it from a farm at Bainsvlei outside Bloem, and the damn horse in the pic bit me...
Posted: Fri Mar 18, 2011 10:28 pm
Hi ALL,
Blitz; Thanks again, still have to tell me if you have a shorter system to load pic,s then Eden,
Ooops, Eben.
As far as model go's, it has some 68 in it, but the vin # falls in the year 67
Karmakoma; You right, my old morris 10 was rust held together with small body parts.
But the more i wire brush, the more it seems local to normal spots, with surface rust between.
Must say that I am on the 2nd drilling machine already, not to mention the round wire brushes that do the work.
Pine; It would look like the same fasty, did get it in Flowerfountain, thats not far from Crowntown.
Would love to get more history on it, as it seems as if it has been standing for a long time.
Do you know who painted it ?
and fitted the carpets. Do you know what year it was 1st registered.
With regard to what I paid for it, well I do not kiss and tell, not yet anyway.
may get in the way of business
Must send the crome to JHB, but forgot the name of that firm that repairs and plates all in one ???
sent the morris parts there !!
well till next time.
Posted: Sat Mar 19, 2011 8:20 am
by Dawie
For rust removal, try one of those small "one hand angle grinders". Wire brushes are available for these. They spin at around 11000 rpm's instead of a drill's 3400 rpms. Sanding discs are also available for these.
For a drill, there is a type of composite black plasicky looking wheel thingy, (made by scotch an others). A bit expensive, but they are excellent and efficient for rust removal uses. Seems like they bite through the rust, instead of wire brushes that sometimes gives the impression that they are sort of being "lubricated" by the rust , or just "spreading the rust around". (Not the correct tecnical terms, but once you have tried the various methods, you may understand what i mean). Best is to first use the "scotch" wheel, or coarse sanding disc, followed by the wire brush.
Posted: Sat Mar 19, 2011 11:26 am
Hi Dawie,
Fair comment.
The thing I find is that as most panels are shaped like a women, more curves then straight parts,the sanding disk as well as the scotch disk tend to leave flats, and removes badly needed metal (to keep the car in one piece)
I do not know if you have ever worked with "rust converter". Well for those that have not, let me explain,
The hole idea of rust converter is to retain as much metel as possible, not like the old days when you were told to "remove all rust or it will come back".
So all you want to do is get to the 1st layer of metal with rust pit marks, this can be done with a good wire brush. You than paint the rust converter onto the area, ensuring full wetnes, sit back and see it change from pink to black.
When black you know you have stoped the rust and converted it chemicaly to an non-oxide product. Now you have to coat it within a day to stop the oxgyen from getting to it again. Please note it must be a final coat and not just a primer, as a primer is not air tight.
Should you use a under floor rubber compound, you then have a strong fix. And here endith the lession
With regard to the grinder, I have one with brush, but this is not for the faint hearted, boy what a ride
and not late at night
Well let me at it again,
Till next time
Posted: Sun Mar 20, 2011 12:49 pm
Hi All,
sorry that I changed the thread title, but received good news from expert, the fasty is a 1968 and not 1967.
Blitz you were right, sorry pal.
Posted: Sun Mar 20, 2011 1:09 pm
by eben
...the give-away? .... the fuel-flap arrived in '68
Posted: Sun Mar 20, 2011 3:52 pm
Ja Jong !!!!
When you thick, then it is easy to forget that all the old things were shipped to SA in the old days, even if the Vin # said that it was made in 1967, the car only went through the factory in 1968. but
it is a 1968, which means more parts, easy to get.
Have done most of metal work in inside the fasty and have sealed it to the big bad oxygen.
Trying to get pic's on, well here goes.......
Motor sounds broke,
Chrome is going to JHB via african platers (the best)
Seats are off to my own little "sweat shop" with the rest of the carpets
now I have to start with the drive gear,
Impi ; thanks for all good ideas,
