All I can say is: WATCH THIS SPACE!
Good idea but the cops will can you for it.RICKY-R69 wrote: I got a set of angel eye crystal headlights for the bus as well. They should work wonders with the correct headlight globes. What globes would you guys suggest?
Good in theory, but in practice I am not sure.RICKY-R69 wrote: If I still don't have enough airflow to the radiator I will add a jetta 3 aircon pump and incorporating it with a booster fan blowing cold air on the radiator. What do you guys think? Will this work?
